Img_9511
Img_9511
Do you have a buck tag for this car? (It is sometimes hidden so look closely.) Do you have a carb tag or an engine calibration sticker (on side of factory valve cover)? Do you have a window sticker, owner card, or build sheet? How many miles on the odometer? Does it have any of the following options?
air conditioning
cruise control
light group (under hood light, buzzer when exterior lights on, etc.)
power lock group (power door locks, remote hatchback release)
power side windows
premium sound system (if so will say "Premium Sound" on factory radio face plate, if not will say "Electronic" on factory radio face plate)
rear window defroster
tinted glass (brown or blue tinted upper band on windshield and slight green tint to side and rear glass)
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
i do have the buck tag.cant get to it until saturday.thanks though!
It does have a/c,power windows,under hood light,power gas door,power door locks,power hatch,rear defrost and cruise control.it does not have tinted glass
VIN
1FA = Ford vehicle manufactured in USA
B = active belts, no airbags
P = passenger car
28 = Mustang 3-dr hatchback
M = H.O. 5.0L V8 engine
6 = VIN check digit
F = 1985 model year
F = Dearborn Assembly
141691 = 41,691st 1985 Ford scheduled for production at Dearborn Assembly
Door Tag
Date - 12/84 = December 1984 scheduled production
GVWR - 4051 lb/1837 kg = gross vehicle weight rating
Front GAWR - 2137 lb/969 kg = front gross axle weight rating
Rear GAWR - 1934 lb/877 kg = rear gross axle weight rating
F0024 = 24 lbs front accessory reserve load
R0051 = 51 lbs rear accessory reserve load
Exterior Paint Colors - 9L = Oxford White
DSO - 22 = Charlotte district sales office
Body - 61B = Mustang 3-dr hatchback
Int Trim - PA = cloth Articulated Sport seating (P), Charcoal/Grey interior color (A)
A/C - 1 = Dark Charcoal hood stripe, Medium Charcoal "Mustang GT" hatchback decal
R - 6 = electronic AM/FM stereo search radio with cassette tape player
S - C = flip-up open air roof (sunroof)
Ax - M = 2.73:1 axle ratio, Traction-Lok (limited slip) differential
Tr - 2 = manual Borg Warner transmission (5-speed overdrive T-5)
BB = front springs
BB = rear springs
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
MUSTANG = Mustang model line
MO = moonroof (sunroof)
053_ = body & paint rotations #053_
9L = Oxford White exterior paint color
DF
ST
AC = manual air conditioner
04 = YES rear defrost, YES rear wing
S = speed control (cruise control)
GT = GT model/trim level
WD = power side windows (W), power door locks (D)
MBW = manual Borg Warner transmission (5-speed T-5)
01 = no hood scoop
EL
A = Charcoal/Grey interior trim color
04
1
X
2 = solid roof/sunroof door with power locks and/or power windows
NLR
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Sweet! Thanks!
