Results 1 to 9 of 9
Thread: where does this
    FEP Power Member 86darkside's Avatar
    Jan 2009
    new jersey
    Default where does this
    anybody have any idea where this connector go located to..? i been connecting all the ones underneath the dash its coming from the left hand side looks to be going towards the steering colume but i connected the ones that go in there...thanks
    Apr 2010
    Portland, Oregon
    Light green/red hash & red/light green? Brake switch.
    Jan 2009
    new jersey
    awsome thanks....
    Jan 2009
    new jersey
    whoa found this one ....
    any ideas...?
    its black and purple
    Maybe horn.........just a guess.
    Jan 2009
    new jersey
    thats what im thinking cuase its right below the wheel and it has no cruise control
    FEP Member vdubn's Avatar
    May 2017
    Beaverton, Oregon
    It is the horn, I am putting the same stuff back together as you.... I think that connects to the dash harness, but not sure where... I was trying to figure that out last night as well, but no luck finding the other half of this connection. If you figure out where it connects, please post it.
    May 2014
    Royal oak Mi
    Can anyone confirm that blk/purp harness connects to a 4 pin connector under the center of dash on a NON cruise 3 spoke wheel for 85 gt..
    Please see post/pic above#4
    I have not seen anywhere this BLK/Purple 2 wire shell connector could plug into except a 4 pin shell with a nice plastic sheath loom OEM over the 3 wire 4 terminal which the connectors "fits-half of the shell"
    its a 4 pin shell, with 3 terminals and with 3 wires and would be installing a 2 pin connector (see pic in #4).. if I plug this 2 female blk/purple connector into the gray male 4 pin connector the following result would be..
    half of the 4 pin shell would be left open with (1) empty spot, never terminated from the factory.
    and (1) terminated black wire left open ( assuming this maybe a cruise control or different accessory)
    Just looking to replace a factory horn fit/ function on a non- cruise 85 gt 3 spoke wheel
    Any help is appreciated
    May 2014
    Royal oak Mi
    Just heads up this black purple wire harness does connect to the 4 pin grey harness near the bottom of column
    The grey connector has yellow with green stripe and a black wire that doesn't connect to anything and a blue wire with black stripe
    It's a connection that leaves half of the connector open for something else or maybe a cruise control acessorie
