    Default 1983 Full Tank Fuel Leak
    When I fill my tank in my '83 GLX vert it leaks fuel until I burn off a couple gallons. Is this the tank or at the connection between the tank and the fiil hose or a cracked fill hose ?
    Sep 2008
    Greenwood, IN
    Tough to tell...can you not see where it is coming from? Most likely culprit is the rubber grommet where the filler neck enters the tank has deteriorated. Its a ~$17 part and a pretty easy fix. The filler neck is metal as I recall, or plastic...not a rubber hose. It could be bad I guess, but I would bet on the grommet. I guess the other culprit could be a rotten tank with a hole somewhere...in that case a new tank is also an easy replacement. Either way a grommet, filler neck or tank are all readily available with good youtube videos out there on how to do it.
    Jason Smith
    MCA #65481
    '82 Capri RS Resto-Mod
    '05 S-281 Mineral Grey
    It is definitely coming from the top of the tank - I'm betting you're right about the grommet. Thanks
    Turned out it was a hole in the tank at the seam at the rear of the tank where the strap passes driver's side.
