When I fill my tank in my '83 GLX vert it leaks fuel until I burn off a couple gallons. Is this the tank or at the connection between the tank and the fiil hose or a cracked fill hose ?
Tough to tell...can you not see where it is coming from? Most likely culprit is the rubber grommet where the filler neck enters the tank has deteriorated. Its a ~$17 part and a pretty easy fix. The filler neck is metal as I recall, or plastic...not a rubber hose. It could be bad I guess, but I would bet on the grommet. I guess the other culprit could be a rotten tank with a hole somewhere...in that case a new tank is also an easy replacement. Either way a grommet, filler neck or tank are all readily available with good youtube videos out there on how to do it.
Jason Smith
MCA #65481
'82 Capri RS Resto-Mod
'05 S-281 Mineral Grey
It is definitely coming from the top of the tank - I'm betting you're right about the grommet. Thanks
I just replaced mine on my 85. Actually got the seal on amazon.
Had to drop the tank a bit to get it on.
1985 Mustang GT Hatch, Black/Grey - 351w / 5-speed / 8.8 Rear w/3.73's / A/C
__________________________________________
Past Owned Four Eyes -
1986 Mustang SVO, Black - sold 1/19
1985 Mustang GT Convertible / Black on Grey / 5spd / 27k original miles
1985 Mustang GT Hatch Canyon Red w/grey int / 5spd
1985 Mustang GT Hatch Canyon Red w/grey int / Sunroof / 5spd / 46k original miles
1985 Mustang GT Convertible White w/gray int / 5spd
Turned out it was a hole in the tank at the seam at the rear of the tank where the strap passes driver's side.
