Hi guys, got a Capri few months ago, 134,000 so far, how Can I tell what my sub model is? MY vin is 1MEBP67B6CF603064
Because the paint option is special tu-tone ("1CC 6Y" on the buck tag) AND there is no code for RS or Turbo RS on the tag, that means it could only be a [base] or a GS. (Special tu-tone paint was not available on the L, RS, or Turbo RS, and the [base], L, and GS do not have a model code on their buck tag.) The [base] and GS each had seating type and material that were not available in the other but the buck tag only shows the color of the interior trim ("-A"), not the seating type and material, so I need to see the door tag.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
I cannot believe I did not notice this before but it cannot be a GS, because of the "61D" code on the buck tag. (GS would have been 61H.)
Are the front bucket seats "high-back" or "low-back" (with an adjustable headrest)?
VIN
1ME = Mercury vehicle manufactured in USA by Ford Motor Company
B = active belts, no airbags
P = passenger car
67 = Capri 3-dr hatchback
B = 3.3L I6 engine
6 = VIN check digit
C = 1982 model year
F = Dearborn Assembly
603064 = 3,064th 1982 Mercury scheduled for production at Dearborn Assembly
Door Tag
Date - 08/81 = August 1981 scheduled build
GVWR - 3934 lb/1784 kg = gross vehicle weight rating
Front GAWR - 2219 lb/961 kg = front gross axle weight rating
Rear GAWR - 1845 lb/836 kg = rear gross axle weight rating
F0186 = 186 lbs front accessory reserve load
R0097 = 97 lbs rear accessory reserve load
Exterior Paint Colors - 1C 6Y = Black upper and lower (1C), Medium French Vanilla center (6Y)
DSO - 52 = Los Angeles district sales office
Body - 61D = Capri 3-dr hatchback
Int Trim - DA = cloth & vinyl seating, low-back buck seats (D), Black interior trim color (A)
A/C - A = manual air conditioner
R - 7 = AM/FM stereo radio with cassette tape player
S - [blank] = no sunroof, no T-roof
Ax - 8 = 2.73:1 axle ratio, non-locking differential
Tr - C = C5 automatic transmission
ZZ = front springs
GG = rear springs
Buck Tag
CAPRI = Capri model line
B = 3.3L I6 engine
0021 = body & paint rotations #0021
1CC = Black upper and lower exterior paint color
6Y = Medium French Vanilla center exterior paint color
ST
AC = manual air conditioner
02 = YES rear defrost, NO rear louvers, NO rear washer/wiper, NO rear wing
HB = heated backlite (rear defrost)
02 = vents in hood, no hood scoop
V = visibility (light group)
-A = Black interior trim color
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
It has low back seats with black and white tweed like material with the adjustable headrest, is this vehicle worth anything? It doesn’t have the original paint anymore. Everything else is original.
Here’s a pic from 1984-ish. My great grandma bought the car new. Still have the hubcaps
Nice color combo.
Current rides:
89 LX 5.0, 5 -spd..the Lemon
86 RS Capri 5.0 Auto...
85.5 SVO, Finally Got Boost
I was having trouble figuring out what the first character of the INT TRIM was. Couldn't tell if it was B (high-back) or D (low-back).
This car is a Capri L.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
There may have been an "L" badge on the hatchback liftgate but I'm not sure.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Thank you so much for helping, I do want to restore the car 100%. It does seem reliable and a easy fix for anything
Sweet car! Please show the interior.
I will soon as I can. The interior has the normal wear on any old car. All original. Torn seats, cracked dash. The paint is painted blue now.
Haven’t work on the car for a few months.. it’s having a fuel issue where the carb bowl is empty. I really want to restore but it’s just I don’t know where to start.
