Results 1 to 3 of 3
    FEP Member vdubn's Avatar
    May 2017
    Beaverton, Oregon
    Default Information/Check Center, Low Fuel, Light Monitor, Clock, etc.
    SOLD
    I have a complete information center (actually a couple of them), from my 1985 Mustang GT. Should be the same for all of the Four Eyed cars, just not sure when Ford first started putting these into the Mustangs.
    This one has red bulb covers, so I am guessing that it lights up red-ish
    It looks to be in good shape, $50 shipped for what you see.
    May 2017
    Beaverton, Oregon
    8550capri, clear out some PM's, I tried to send you one. You can paypal me at dean@vdubn.com if you want this.
    Hello, I just sent the funds to your PayPal address. Thanks
