Results 1 to 16 of 16
Thread: Intake choice
    Dec 2011
    stanton,alabama
    Default Intake choice
    Which intake is the best choice 331 stroker torker2 or rpm airgap
    FEP Member brianj's Avatar
    Feb 2012
    Raymond, New Hampshire
    Blog Entries
    2
    Name:  2016-10-13 18.54.08.jpg
    Or, if you must settle for less, I'm partial to the Performer RPM. I'm making the assumption that you will not be spending a lot of time over 5000 RPM, though. If you built it to ring it up to 6800 on a regular basis, that changes things.
    Dec 2011
    stanton,alabama
    shifting at 6200
    Feb 2012
    Blog Entries
    2
    I'd vote Performer RPM. I ran one for years, and was quite happy with it. It's still sitting on a shelf, ready to go on the next n/a motor I build. A single plane intake like the torker is great for top end, and honestly probably does not affect your low end torque that much, but it can be a bit finicky and herky-jerky from a stop, or when cold. Many people run single plane intakes daily without complaint, but it's not for me.
    Dec 2011
    stanton,alabama
    thanks for that info
    Air Gap 7521 (?) shows some nice dyno graphs for what its worth. I will likely try one on my Saleen clone.
    Mar 2015
    Rose Hill,Kansas
    I am going with the 7521 also on my engine build.
    What kind of heads and cam and compression? I'm not sure how anyone's talking about an intake without knowing that.
    Dec 2011
    stanton,alabama
    Quote Originally Posted by Just1986 View Post
    dad level20 331 trickflow185cnc heads 533,544 comp cam around 10:1 compression 5 pad car 100 to 150 shot of nos
    Jan 2011
    Vancouver BC Canada
    Since you posted this question in the race tech section, I have to ask if this is more of a race car, or street car.My own 331 does not see any street duty, it is also 10.0 compression, with untouched AFR 185 heads, a .570" lift Comp solid flat tappet cam, amd a 650 Holley.My trans is a Jerico 4 speed, and used 4.88 or 5.13 gears, depending on if if was in my 85 Mustang with 29" tall slicks, or my Fairmont with 31" tall tires. I shift at 6800 RPM, and in good conditions, crosses the finish line a little over 7000. I have tried a Performer RPM, an Air Gap RPM, and currently use a Ford Motorsport single plane, basically a Victor Ir. with a Motorsport logo and part number. On my car, the single plane is hands down the quickest and fastest, mid 10.20 ETs vs 10.4s for the AirGap. But like I said, I don`t street drive either car.Also, I don`t use nitrous, but I would think that a single plane would likely be more efficent with a single plane. JMO.
    Quote Originally Posted by tonysilver82 View Post
    I wouldn't put anything less than a Victor JR on there. That car's gonna pull hard between 4000-6500. That's Victor JR Territory.
    FEP Member Mgino757's Avatar
    Jan 2011
    Virginia Beach, VA
    I'd run a Weiand Stealth, they're good up to 6800 rpm with it's big runners. Edit:Found your cam. I second my intake suggestion.
    FEP Supporter BMW Rider's Avatar
    Oct 2014
    Calgary, Alberta, Canada
    You need to consider how you want to use the car and the engine.
    A single plane manifold will be best when the engine is into the rpm range it is rated for, typically that will be higher constant revs as in drag racing. A single plane manifold under those conditions will out perform a dual plane. At low rpm and under variable throttle a single plane will perform poorly. This is where a dual plane manifold will be a far better choice giving you better throttle response and driveability. A good dual plane will still perform well into higher rpm ranges.
    Quite mild camshaft = dual plane, better choice.
    New User
    Nov 2006
    Glen Williams Ontario
    just a quick mention, if you end up with the RPM intake you should at the very least have it gasket matched to to your heads
    Default Intake
    I have a Hurricane air gap single plane polished aluminum I ran for several years on my 347, it is amazing, it will pull crazy hard well past 7000 if you needed, I ran a 347 with Rpm performer heads and and 750 cfm with a 575 in. lift cam and it was a street monster on pump gas and A/C. I went all back to stock because I'm done wanting a low 11 sec car.........high 12's makes me happy. $200 would take it to the next owner.
