Results 1 to 10 of 10
    Default JB Weld and engines
    A few times in the past I've suggested using JB Weld in some situations where others might have went hmm. Stuff like fixing the threads on the bolt that holds down a carb. Or to cold weld a thread insert to the block in a cooling system.
    i just wanted to share a video that shows why I don't think it was a completely insane idea.
    https://youtu.be/587RuL45jS8
    I've never taken it to that extreme, but I have used it to address problems where I couldn't see another way and had it work.
    -- James
    My four eyed foxes:
    past foxes -
    And to think I had been saving for a set of aluminum heads!
    Jb weld has its place but I've seen more fails then successes over the years as a car guy. I don't knock the guys who try but I'm thankful to have access to a TIG and MIG welder for steel and aluminum.
    Barboursville, WV
    I've never had much luck with it, personally.
    I've recently started using it, and it's pretty handy stuff! I haven't tried to use it to WELD though. Fun video!
    Barboursville, WV
    I'm sure it has its place, but I've tried using it many times for thread repair and it never held. Maybe I was doing something wrong, but I don't think so. I gave it plenty of cure time, didn't over-torqe, etc.
    It worked on the carb bolts on my intake years ago. Filled it, drilled it, tapped it, chased it with the stud I was going to use with a notch cut in the end. Worked it in and out slowly taking my time. Got it in and it held up for a long time
    Apr 2006
    Dallas, TX
    I've seen JB Weld used many times, sometimes as a "get you by in a pinch" and sometimes it was intended as a permanent fix by a true believer. Only a few times did it really hold up well and those places seemed indestructible. Mostly is just makes a mess, comes back apart, and is more trouble than it is worth compared to a correct repair. I learned as a teenager that it usually takes longer to make a half assed repair than it does to fix it correctly the first time after you factor in all of the refixes that are usually necessary. This isn't intended as a slight to those who have had good results with JBWeld, just sharing my experience and opinion.
    Used JB on the stock 4bbl carb where the fuel typically leaks from that end plug/cap next to where the feed tube goes to the secondary bowl.
    Held up for about 8 years of daily driving but couldn't handle being parked for 15 years.
    Last resort is a good term for it. That's when I've used it - as a last resort. I'll never trust it for anything where it's not obvious when it breaks
