Results 1 to 7 of 7
    Default Will 14" fit my...
    ...1983 GLX that has the TRX with Handling Pkg?
    I found a set of the stock 14" that I'd like to replace the
    now-unsafe TRX, just wanted to be sure brakes and other components
    wont be in the way of those 14".
    Thanks!
    Nov 2010
    Citrus Heights, CA
    Yes, they will. When I had my '84 GT convertible, it was originally equipped with the TRX wheels. I refurbished a set of the 14" cast aluminum wheels, got a new set of tires and had a shop swap them out .
    Bryan
    1983 Mustang GLX Convertible
    Sep 2008
    Greenwood, IN
    Same as Gemini...yes they will fit no problem. Not sure what the difference was in the "TRX package" other than maybe springs or struts/shocks...but the brakes were all the same. I use to own a set of 14" that I would put on my 82 GT and 83 GT (TRX cars) on occasion for driving...to preserve the original TRX tires.
    Jason Smith
    MCA #65481
    '82 Capri RS Resto-Mod
    '05 S-281 Mineral Grey
    Cool - Thanks guys!
    Trx package could give ya metric sized tires. They are around 15.4" and the tires cost about $600 a piece.
    14" rims fit fine with 10" front discs. 15" would be required if you swap to the later 11" gt brakes.
    How about tire sizes? Would 215/70-14 work front and rear? Anything larger?
    TireRack.com doesn't have much in the standard 205/70-14 size, and a centimeter wider wouldn't be bad...
    as long as it doesn't rub on anything. Keeping stock brakes on it too.
    Thanks again
    Run a tire size calculator.
    I like the tocoma world calculator. It just done really well. It helps visualize and show differences in sizes.
