Results 1 to 8 of 8
Thread: Hood props
    Default Hood props
    Looking to get rid of my hood prop rod. And install hood prop shocks. What the best to get ?. Thanks
    FEP Power Member Mikestang's Avatar
    Aug 2013
    Firestone, CO
    I think my kit was from Redline? Love it.
    1986 Ford Mustang GT-
    Not much stock stuff left
    347 NA power, CNC ported heads, Extrude honed Trick Flow Intake, Custom Cam
    Suspension, custom k- member, TQ arm/pan hard rod... Much more
    Restored and ready to race, made to go fast while cornering
    1981 Mustang GT-
    Old SCCA A-Sedan National Champ car
    In the middle of rebuild
    1986 LX Sedan-
    Plans to be determined...
    "Every day I learn how much I don't know"
    Default RT hood strut notes
    2011, installed Redline Tuning's QuickLIFT 70.00 kit in the Mustang.
    Ordered direct from them.
    100% satisfied.
    Liked them so much on the Mustang, installed a QuickLIFT kit on the Ranger soon after.
    Have a smile every time they open the hood for me. Time savers.
    Hood has factory hood scoop.
    Hood has Ford Racing hood pin kit.
    Pull hood release; hood latch releases, then hood rises a little, just as before.
    Opening and closing hood is now same procedure as a hatch.
    Struts open and close hood the same rate as a hatch with good struts.
    Hood stays up securely, even in gusty winds.
    Work fine in cold weather.
    Hood wide open is now at a nicely higher angle than with the prop rod (which i removed).
    Found out hood struts really do not block access to anything.
    Struts are also more classy when poppin' the hood to show off the engine.
    Instead of blocking the first impression, you get to stand back, watch the curtain rise, and see the reaction.
    Have to add; is comforting to finally feel safe looking or working around back under there in the engine bay.
    No worry of being 'bit' hard by the hood when the prop rod comes out of the hole, due to wind gust or a shoulder bump to the hood.
    I have them on my 90 vert. Love them and maybe a 30 minute install.
    1986 GT T Top- stock except for magnaflow cat back
    1990 LX vert- 500hp V3 and all that stuff
    2013 GT- usual bolt ons
    I guess I'm weird. I've rid myself of factory spring hinges and installed a prop rod on a few cars.
    Mar 2015
    Rose Hill,Kansas
    I tried the sve hood kit, didn't work. Pushed hood forward and up at cowl ended up taking them off.
    FEP Super Member escogt's Avatar
    Jan 2006
    Long Island, N.Y.
    The Redline kit is perfect. I have it on my '85GT & love it!!!
    '85GT Bright Atlantic Blue
    '92LX Bimini Blue-sold
    '93 COBRA Teal Metallic-sold
    '86SVO Oxford White-sold
    '86GT 'Vert True Blue-sold
    '81'GT' Medium Red-sold
