Results 1 to 2 of 2
    Jul 2016
    Duncannon PA
    Default Ford Motorsport valve cover
    I am going to put my Ford Motorsport valve cover on my 84 SVO.
    The rear hole is 1 1/8 inch and would normally have a grommet and PVC in it. On the svo vc though there is just a 3/8 nipple permanently mounted into it. Has anyone else used the Motorsport piece and if so what did you do about the line to the vc to the turbo?
    Jan 2004
    Arlington Washington
    Here this is what you would need, can be found in 86-88 turbo cars I think... http://drivingline.prd.s3.amazonaws....Roundup-11.jpg
    1982 Capri RS 5.0L
