I have an 86 5.0, and the HVAC blower isn't as strong as it should be. If I put it on low, you can feel it barely through all vents, as I increase it to MAX it does increase, but it's probably 1/3 what it should be through the range. This goes for vents, defrost and floor. I'm under the impression when the resistor goes, it just stops working. Does it sound like the resistor could be partially working, or possibly a bad or failing blower motor? Any ideas appreciated.
