Results 1 to 9 of 9
Thread: V8 to Turbo 2.3
    FEP Member svo84's Avatar
    Oct 2006
    York, Pennsylvania
    Default V8 to Turbo 2.3
    Hello All, here is my idea. I have a 82 GT auto that I am kicking around the idea of putting in a turbo 4. The motor and tranny swap is pretty straight up. My concern is the wiring.is there a difference between turbo and V8 cars ? Sticks and autos ? I do want this to be a draw through turbo system like the 79-81 system with an automatic transmission. The car is super clean and low miles so I would like not to butcher it up. If I am missing any info please let me know. Thanks you.
    I did this same swap to a Fairmont wagon years ago. The only issue that I remember was the fact that the alternator is on the opposite side of the engine and I had to get a alternator wiring harness from a 4 cyl car. If I can think of anything else I'll post it but i think that was it.
    Parts are mostly scarce for the guys running a turbo 4 from the factory. I would find one that is already or leave it alone or modernize it.
    Example - turbo 4 from the ecoboost
    https://youtu.be/aJn75u9C3SQ
    FEP Senior Member ddx77's Avatar
    Jul 2011
    Fort Lauderdale, FL
    That's impressive!
    FEP Senior Member E2ZZGLX's Avatar
    Jan 2012
    Broomfield Colorado
    Direct "plug n play" I did this to my 82 GT back in the day between engine builds to keep it on the road. The only thing that maybe difficult is the kick down linkage if wanting to run an auto, also rember you will need to swap ratios in the rear to keep her fun!
    Current keepers...
    77 Cobra II
    80 Bobcat Sport
    82 GT-first new car is back home!
    85 ASC Coupe
    86 SVO
    86 Escort GT
    88 Ranger GT
    FEP Power Member BLK BRD 88's Avatar
    Dec 2010
    Next to the Chimney
    Quote Originally Posted by ddx77 View Post
    That's impressive!
    It is impressive, and how about gaining 64hp to the wheels with a tuneup?
    I never seem to get the nut that holds the steering wheel fixed
    If your serious abot this swap the only way to do it is with efi. You could do a factory looking 2.3t swap with nothing more than junkyard and donor car parts and reach 250-300hp fairly easy.
    Brian R. of Michigan
    83 TBird 5.0
    88 Ranger 2.3t
    http://vb.foureyedpride.com/showthre...83-Tbird-build
    Oct 2006
    York, Pennsylvania
    Thank you for all the input. Yes ecoboost Mustang are impressive. I would like to stay old skool with this one. I have seen a couple of turbo Mustang running auto X and ran pretty good. I have also owned 2 SVOs in the past and know the efi side pretty good. Thank you again
    Dec 2010
    Next to the Chimney
    Quote Originally Posted by deathbypsi View Post
    EFI will also mean that you need the wire loom and computer that goes with it, but I agree, that is the way to go if you are going to turbo it.
    Ron
