The car is a V8, no air, sunroof and back widow louvers. Car has 26k miles on it but has been resto modded. Some good, some not so. Interior is near perfect. Exterior is a solid 9 out of 10. 5 lug conversion. 8.8 Lincoln rear. WC T5, 3.73 rear. 90 roller cam 302 with a TF stage 1 cam. I need to sort out a rear brake line that was run under the car. A gas line that was cut and run weird as well. I just added full length SFC. Upper and lower J&M arms and a rear sway bar. The rear end needs a full rebuild as it blew up on the way home.
Seems I have some sort of water leak on the drivers side, maybe up by the dash??? Need to put in a bigger master cylinder and start to de-chrome the engine. They did the accessories hoge-podge and I'm definetely nor digging it.
Sent from my SAMSUNG-SM-G890A using Tapatalk
