Results 1 to 8 of 8
    Jul 2016
    Duncannon PA
    Default Map/dome light styles
    I need to find a new map light for my 84 svo. Everyone I've seen so far is not the same as the one I have. Mine is longer with both a dome light in the rear with a map light closer to the windshield.
    Does anyone know of a source for new ones or am I looking for a good used one?
    The map light portion looks common. Can you buy a typical one, disassemble it, and swap it into yours?
    1985 GT owned since new
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Some additional repair info I have hung onto. I ended up finding a decent replacement and never had to do these myself.
    http://www.ascmclarencoupe.com/Proje...htRestoration/
    Member Negusm did this write up.
    Jul 2016
    Duncannon PA
    No the plastic body is the problem. The plastic has become brittle and is broken and epoxied in a couple places. If I can't find one I will use panel bonding adhesive to "rebuild" where it needs it but I'd rather just find a better one.
    Portland Oregon
    Pinto's/ Bobcats and Mustang II's use a similar style but they have the notches for the sun visor pins so make sure you look closely before you pull the trigger. I might have one like yours. It is black though. Let me check when I get home.
    67 Mustang Coupe
    96 Tangerine GT
    86 Saleen #179
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Ah, gotcha. I've never seen repros available. Similar to Tigger, I have a spare canyon red one if you are in a bind. The latch has been fixed but you can have it if you want for the shipping. Tigger's shipping would cheaper from the US though.
    Apr 2010
    Portland, Oregon
    Like this one in Fairmonts?
    Jul 2016
    Duncannon PA
    Yeah thats the one. The cap for the spring loaded button and the hole in the center where the one screw goes into the connection to the harness is busted out. Ived fixed it twice so Im done.
