Looking for a good high performance Ignition coil for a 82 gt. Any suggestions.thanks. carburated.
What's the application? Stock motor? High compression? Boost? Nitrous?
The answer depends. The stock coil is great on a stock motor.
The E coil design is more efficient than the old round ones. I just run a MSD one on my blue car, high compression motor, NA. Works well
1986 Ford Mustang GT-
Not much stock stuff left
347 NA power, CNC ported heads, Extrude honed Trick Flow Intake, Custom Cam
Suspension, custom k- member, TQ arm/pan hard rod... Much more
Restored and ready to race, made to go fast while cornering
1981 Mustang GT-
Old SCCA A-Sedan National Champ car
In the middle of rebuild
1986 LX Sedan-
Plans to be determined...
"Every day I learn how much I don't know"
Like Mike said,
go to the E coil used on later model Fords. Though I would just pull one from the JY.
I'm still using the ACCEL Super Stock chrome canister type Coil for years and works great.
I have a Jacobs coil on mine, not for sale anymore. I believe they sold out to Accel, who removed Jacobs products from the market to eliminate the competition. The old coil still functions well, and keeps the spark lit into high boosted rpm. Plugs gapped at .030, stock gap not working at boost.
Using a later E-core coil on a non-dwell-sensing ignition system like the original Duraspark can cause the ballast
resistance wire to run hotter than it should. And I've never seen any benefits over a stock Motorcraft Duraspark
can style coil.
Don't underestimate the stock Motorcraft Duraspark stuff. It's far more capable than most people understand,
but do avoid cheap generic replacements. The genuine Motorcraft stuff really is that much better.
Cheers,
Jeff Cook
