I am trying to install a Flow Master cat back system on my new '85GT. Problem I am having is one of the hangers that is welded to the rear of the passenger muffler is welded differently then the other. It is welded on an angle leaning against the outlet tube. It is also welded very low and causing the muffler to hit the underside of the floor. I am thinking I just need to get it installed and then take somewhere to get new one welded on and remove the one on it now. Also, which way I am I suppose to install the transmission hanger bracket? With the bracket up or down where the rods welded to the pipe attach? Pis are welcomed.
