Results 1 to 6 of 6
    Default Manual (Non-Power Assist) Brake Master Cylinder Mounting Bracket Dimensions?
    Does anyone have the dimensions of the factory master cylinder mounting bracket for manual (non-power assist) brakes?
    I'm looking to make one. Figuring out the hole spacing is easy enough, it's the angle of the MC mounting face that I'm most concerned about.
    Jan 2011
    Vancouver BC Canada
    I am pretty sure that the manual master cylinder aluminum bracket is flat, the master cylinder sits level. I will be racing my Fairmont at Woodburn Dragstrip next weekend (Sept 23-24th). I have an extra factory aluminum manual brake master cylinder bracket that I can bring down with me if you are interested, for 20 bucks.
    Thanks to mcfairmont I don't need to make a bracket. With a factory bracket in hand, I was able to take some measurements and answer the original question in hope that it will help someone else out in the future.
    All studs are 3/8"-16 and are 1.4" long from the face of the plate.
    The two faces are not parallel. The master cylinder is angle up by ~4.5 degrees.
    Jan 2011
    Vancouver BC Canada
    Funny, I have had several of those brackets and never noticed the tilt of the master cylinder before. Hope it works well for you. By the way, we spent a few days after the racing at Woodburn, visited with Ken at Oregon Cam, had lunch at Pied Piper Pizza , and found some parts for my 59 Ford aat All American Classics, all in Vancouver WA. Also went to the Aviation Museum in McMinnville OR, and the "World of Speed" car and racing Museum in Wilsonville OR. I strongly reccommend both museums. Good luck on your LTD.
    I'd love to swap to manual brakes on one of my cars.
