86 mustang gt convertible 5.0 5 speed car is in good shape for it age. The engine has 30,000 miles its a rebuilt stock 89 bottom end with trick flow 170 heads comp xe 270 cam 1.6 rr explorer gt40 intake and 70mm throttle body. I converted it to mass air. Clutch has 25,000 miles on it has 87-93 11" front brakes 3.73 gears. This spring I replaced the rear control arms with sve tubular and welded in torque box reinforcement plates so drivetrain and suspension redone front to back. The car runs and drives great is ready to drive. Welded subframe conectors. I replaced the top 4 years ago. The one time I went to New England dragway the car ran mid 13s with a slipping clutch and no traction. Witch is a lot better since redoing rear suspension and 245 instead of 225 tires. It should run high 12s now. I've daily driven car in summer for 9 years. call or text 207415-3491
