What is the CFM for the Holley that Ford put on the 2.3? I'm thinking of fabbing an adapter to mount two, 2V's on a 289 using a 5.0, lower FI intake plenum. The two would both fuel continuously as opposed to a primary and secondary carb and would be mounted with the venturi in a straight line, not 2x2, with the throttle shafts inline with each other. The 2.3 Holley would be ideal since I wouldn't even have to modify the direction of the throttle lever action.
