    Sep 2016
    Anchorage Alaska
    Default D&D tubular K member
    Came across a D&D tubular K member for free in excellent condition, but without A-arms. Since D&D is out of business I can't order a set of D&D A-arms. I know it's a long shot to ask, but does ANYone know if another brand of tubular A-arms will work with the D&D K member?
    I have no experience with the D&D stuff, so I can't answer specifically.
    My understanding is that Brandt Racing took over the K member and began making them when D&D went out of business. I believe they made some changes to improve the fitment of the K member, but they probably have more information as to what will or will not fit. Good Luck!
    http://www.brandtracing.com/index.ph...cts/suspension
    Sep 2016
    Anchorage Alaska
    Thank! I'll see what they have to say.
    FEP Power Member Mikestang's Avatar
    Aug 2013
    Firestone, CO
    I would assume u could make QA1 ones work. May need to play with the spacers though. All the aftermarket k members have slightly different widths where the LCA mounts. I modified a QA1 on my blue car and just used my stock lowers with Del-alum bushings
    1986 Ford Mustang GT-
    Not much stock stuff left
    347 NA power, CNC ported heads, Extrude honed Trick Flow Intake, Custom Cam
    Suspension, custom k- member, TQ arm/pan hard rod... Much more
    Restored and ready to race, made to go fast while cornering
    1981 Mustang GT-
    Old SCCA A-Sedan National Champ car
    In the middle of rebuild
    1986 LX Sedan-
    Plans to be determined...
    "Every day I learn how much I don't know"
    Sep 2016
    Anchorage Alaska
    Sounds like I'm in business with Brandt Racing A-Arms! Thanks Trey!
