Results 1 to 10 of 10
    New User
    Sep 2017
    Edmonton, Alberta, Canada
    Default Door data plate for Thunderbird
    May I get a decode, please?Name:  IMG_3353.jpg
    Don't have a whole lot of Thunderbird literature so decoding is not as easy as Capri and Mustang. Do you have a buck tag for this car? How many miles on the odometer? What options do this car have?
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    New User
    Sep 2017
    New to the fox body. Where would the buck tag be located? I can post a picture this evening. The car has air, tilt, cruise, power door locks, power windows, light group, 5.0 litre, aod, and possibly a few other things I don't know about. Mileage is 95,000, with no rust anywhere on the car body.
    Buck tag will be somewhere on the radiator 'core support' (frame that radiator attaches to). I am very much familiar with the location that the Dearborn and San Jose assembly plants placed the tags on the Capri and Mustang but that location may not be the same for the other assembly plants that produced the other 9 Foxes. Your car was produced at the Lorain assembly plant. Your could ask other Cougar and Thunderbird owners where they found the buck tag on their Lorain-built cars.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    VIN
    B = active belts, no airbags
    P = passenger car
    42 = Thunderbird 2-dr sedan
    F = 5.0L V8 engine
    3 = VIN check digit
    B = 1981 model year
    H = Lorain Assembly
    141782 = 41,782nd 1981 Ford scheduled for production at Lorain Assembly
    Door Tag
    Date - 03/81 = March 1981 scheduled build
    GVWR - 4414 lb/2002 kg = gross vehicle weight rating
    Front GAWR - 2387 lb/1082 kg = front gross axle weight rating
    Rear GAWR - 2045 lb/927 kg = rear gross axle weight rating
    F0110 = 110 lbs front accessory reserve load
    R0026 = 26 lbs rear accessory reserve load
    Exterior Paint Colors - 8D = Bittersweet Glow
    DSO - 74 = Seattle district sales office
    Body - 66D = Thunderbird 2-dr sedan
    VR - AW = unknown vinyl roof grain type (A), White vinyl roof color (W)
    Mldg - 55W = unknown molding type/color
    Int Trim - TZ = cloth Recaro seating (T), Vaquero interior trim color (Z)
    A/C - A = air conditioner
    R - 4 = AM/FM stereo radio
    S - [blank] = no sunroof
    Ax = Y = 3.08:1 axle ratio, non-locking differential
    Tr - T = Ford automatic overdrive (AOD) transmission
    EE = front springs
    RR = rear springs
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    New User
    Sep 2017
Size:  151.5 KBName:  IMG_1019.jpg
Size:  151.5 KB[QUOTE=FoxChassis;1857601]VIN
    P = passenger car
    F = 5.0L V8 engine
    3 = VIN check digit
    B = 1981 model year
    H = Lorain Assembly
    Door Tag
    New User
    Sep 2017
    Sorry. Using my phone and triple posted picture. Here's the buck tag for the T-bird
    The buck tag a decoders are the same between all fox bodys pretty much. Radiator to firewall the cars are identical in built, minus cetain k members and firewalls.
    This is the best I can do on the buck tag. I don't have a lot of Cougar or Thunderbird tags so I don't know a lot about the codes on them. The codes with a (?) are a guess. Let me know how I did. Thanks.
    Buck Tag
    0426 = body & paint rotations #0426
    S42B = Thunderbird 2-dr sedan
    8D = Bittersweet Glow exterior paint color
    AC = air conditioner
    ED = exterior decor group (?) (half vinyl roof, RH remote mirror, pin stripes, luxury wheel covers, and wide bodyside moldings)
    CT
    OD
    R = rocker panel moldings (?)
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    New User
    Sep 2017
    Pretty close. Full vinyl roof, no rocker mouldings. Keystone aftermarket wheels, but that won't show on the tags or data plate
