Line X
840312 1553 = build sheet printed March 12, 1984 3:53 PM
Line A
Rotations Number - 5389 = trim & chassis rotations #5389
Line - Z = Mustang model line
VIN - P28EF178722
Body Type - 61B = Mustang 3-dr hatchback
Body, Tops, Roof - 7 = sunroof
Ext, Paint, Body - 9L = Oxford White exterior paint color
Ext, Tutone - [blank] = no tu-tone paint
Int, Trim - PD = cloth Articulated Sport seating (P), Canyon Red interior trim color (D)
Int, Deviation - [blank] = no interior trim deviation
I.B. Color - D = Canyon Red instrument panel color
Type of Order - 2 = Stock-Dealer order
Region & District - 54 = Omaha district sales office
Special Order - [blank] = not a special order
Line B
Emission Control - [blank] = no special emissions package
Engine - M = H.O. 5.0L V8 engine
Trans - 2 = Borg Warner 'T-5' 5-speed manual overdrive transmission
Air Cond - M = manual air conditioner
Engine, Tag Number - EK333AB = 49-state calibration (E), Thermactor emissions with or without A/C (K), 5.0L engine (333), release level AB
Therm, Air Pump - MO = Thermactor air pump for 5.0L engine
Transmission, Part Number - E4ZRDA = manual transmission (R) originally engineered for 1984 (E4) Mustang (Z), release level DA
Seats, Type - V = Articulated Sport seating
Belts, Color - D = Canyon Red seat belts
Carbon Canister - 5 = carbon canister for 5.0L engine with manual transmission
Modules, Ign - 4V = ignition module for 5.0L engine with 4V carburetor
Modules, EEC/MCU - [blank] = no electronic engine control (EEC) module
Air Cleaner, Prefix - E4 = air filter housing original engineering for 1984
Bypass or Divertor Valve - JB = Thermactor bypass and divertor valves for 5.0L engine without California Emission System
Line C
Imm Block Heater - [blank] = no engine block immersion heater
Power Steering, Oil Cooler - A = power steering cooler
Power Steering, Pump - B = power steering pump for 5.0L engine
Power Steering, Hoses - 8G = power steering hoses for 5.0L engine
Pulley, Water Pump - 1A = water pump pulley for 5.0L engine
Pulley, Crankshaft - 4 = crankshaft pulley for 5.0L engine
Pulley, Air Pump - ZA = air pump pulley for 5.0L engine
Alternator, Wiring 14305 - 3D = alternator wiring for 5.0L engine
Alternator, Code - 60 = alternator code for 5.0L engine with manual transmission
Drive Belts - UUUU = drive belt for 5.0L engine with air conditioner
Line D
Groups, Promot - A = G.T.350 package
Groups, Décor, Appear - B = GT
Electrical, Wipers - W = interval windshield wipers
Electrical, Defroster - E = electric rear window defroster
Electrical, Audio, Radio - R = AM/FM stereo cassette radio
Electrical, Audio, Spkrs - Z = four speakers with premium sound system
Electrical, Lights, Light Group - V = visibility/light group
Power Aids, Decklid Release - F = remote decklid release
Power Aids, Locks - [blank] = no power door locks
Power Aids, Windows - [blank] = no power side windows
Glass, Tint - T = tinted glass
Mouldings, Rocker - [blank] = no rocker panel moulding
Mouldings, Bodyside, Type/Color - D = White bodyside molding with Canyon Red inset stripes and Canyon Red strip molding between wheels (G.T.350)
Air Dam - G = GT front bumper cover with foglamps
Road Abrasion - [blank] = no road abrasion coating
Carpet/Mats - [blank] = no floor mats
Console - C = console
Mirror, Vanity - [blank] = no passenger side vanity mirror
Mirror, Outside - A = dual remote-control mirrors
Line E
Battery - DA = regular duty battery (36 amp-hr)
Driveline, Speed-O, Metric - [blank] = no metric speedometer
Driveline, Speed-O, Gear 2 - Y = yellow (C0DD-17271-B) speedometer driven gear
Driveline, Driveshaft, Color Codes - OGB = driveshaft color codes for 5.0L engine with manual transmission
Driveline, Rear Axle, Tag Number - 271E = 3.08:1 axle ratio, Traction-Lok (limited slip) differential
Suspension, Springs, Front, Left - KAC = ''5'' front left spring code
Suspension, Springs, Front, Right - KAC = ''5'' front right spring code
Suspension, Springs, Rear, Left - GAC = ''X'' rear left spring code
Suspension, Springs, Rear, Right - GAC = ''X'' rear right spring code
Stabilizer Bars, Front - YB = Yellow and Blue paint daubs on front stabilizer bar
Stabilizer Bars, RR - P = Pink paint daub on rear stabilizer bar
Pkgs, Hndlng - X = Handling Suspension package
Sus Arm Lower RR - F = rear lower control arms for LX 5.0L and GT
Line F
Wheel Area, Wheel Covers - T = 14" cast aluminum '16 slot' wheel center caps
Wheel Area, Wheels 1/2 - AL = 14" cast aluminum '16 slot' wheels
Tires - 4 = Goodyear tires
Tires, Spare Wheel - A = spare wheel for L, LX, GT, Turbo GT
Tires, Size - 2050VR = P205/70VR14 tires
Tires, Spare - M = temporary (mini) spare tire
Tires, Quantity - 4 = four tires
Speed Control - S = fingertip speed control (cruise control)
Front End, Cover/Pad & Type Wheel - B1 = Ford vinyl molded steering wheel with cruise
Front End, Steering Wheel, Type of Col - T = tilt steering wheel
Clusters - EG = LX 5.0L and GT cluster (7K tach, 85 mph speedo)
Hood Scoop - [blank] = no hood scoop
Frt License Plate Bracket - X = front license plate bracket
Line G
Heat Shield - W = exhaust heat shield for LX 5.0L and GT
Muffler - 3Z9E = exhaust heat shield for LX 5.0L and GT with manual transmission
Catalytic Converter, Left, Lite-Off - AWE = exhaust heat shield for LX 5.0L and GT
Catalytic Converter, Right, Main - LAW = exhaust heat shield for LX 5.0L and GT with manual transmission
Accent Stripe, Type/Color - GD = (5.0L) G.T.350 stripes
Fuel, Sender - 8 = carb fuel tank sending unit
Fuel, No Lead - N = "Unleaded Fuel Only" sticker in English
Fuel, Gas Qty - [blank] = 0 gallons of gas
VIN - 1FABM2
