picked up a parts car, could you decode the Buck Tag.
Current rides:
89 LX 5.0, 5 -spd..the Lemon
86 RS Capri 5.0 Auto...
85.5 SVO, Finally Got Boost
Do you have a door tag for this Turbo RS? Mileage and options?
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
Current rides:
VIN
0 = 1980 model year
F = Dearborn Assembly
14 = Capri 3-dr hatchback
A = non-turbocharged/turbocharged 2.3L engine
625429 = 25,429th 1980 Mercury scheduled for production at Dearborn Assembly
Door Tag
Date - 01/80 = January 1980 scheduled build
GVWR - 3797 lb/1722 kg = gross vehicle weight rating
1982 lb/899 kg = front gross axle weight rating
1835 lb/832 kg = rear gross axle weight rating
F0065 = 65 lbs front accessory reserve load
R0054 = 54lbs rear accessory reserve load
Exterior Paint Colors - 27 1C = Bright Red upper (27), Black lower (1C) tu-tone paint
DSO - 84 = Home Office Reserve district sales office
Body - 61D = Capri 3-dr hatchback
Int Trim - TA = cloth & vinyl Recaro seating (T), Black interior trim color (A)
A/C - A = factory air conditioner
R - 5 = AM/FM stereo 8-track
S - B = sunroof
Ax - F = 3.45:1 axle ratio, non-locking differential
Tr - 6 = manual Borg Warner transmission (4-speed 'SR4')
YY = front springs
FF = rear springs
Buck Tag
CAPRI = Capri model line
T = turbocharged 2.3L engine
MO = moonroof (sunroof)
0957 = body & paint rotations #0957
27 = Bright Red exterior paint color
DF
TT = Black lower exterior paint color (lower tu-tone)
AA
AC = manual air conditioner
05 = YES rear defrost, YES rear wing, NO rear louvers, NO rear washer/wiper
HB = heated backlite (rear defrost)
RA = road abrasion coating (lower bodyside protection)
S = speed control (cruise control)
TRS = Turbo RS model/trim level
PL = power door locks
MBW = manual Borg Warner transmission
10 = vents in hood, hole in hood covered by 'bulge' hood scoop
V = visibility (light group)
1
3
4
5
6
III
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
That looks like a cool car! To bad it's only a parts car. Will you be posting any pictures?
88 Turbo Coupe auto
88 Turbo Coupe 5spd
79 Fairmont Futura 4.6
80 Capri 5.0/5spd project
79 Pace Car 5.0/5spd project
86 GT conv 5.0/5spd
So it didnt have factory louvers...
According to the buck tag it did not have factory louvers. No "LL" code.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Aaaaahhhhh.... "LL" ok got it.
