Going carb not efi on new engine build, will i lose my cruise control. Not removing any wire harness unless necessary. Computer most likely
As long as you have a way to hook the linkage to the throttle, no. It's not controlled by the ECU, it's vacuum regulated with it's own servo unit.
1986 CHP SSP Coupe
