Results 1 to 3 of 3
    FEP Member vdubn's Avatar
    May 2017
    Beaverton, Oregon
    Default Can These Solenoids be removed/eliminated
    These are under the passenger side fender on my 85, and through the process of converting over to fuel injection, can I just eliminate these? Are there similar solenoids on the 1986 harness I'll be switching to? I don't have the 86 headlight harness yet, so just trying to determine what I can live without, and what I need.
    Apr 2008
    Waikoloa , Hawaii
    For your EFI conversion, you only need vacuum for the brake booster, the fuel pressure regulator, and if you're running EGR or any smog, that stuff.. All that can go.
    1986 CHP SSP Coupe
    May 2017
    Beaverton, Oregon
    Awesome!
    Now I just need to find the last two harnesses.... headlight and rear body (one with tail light sockets LOL
