Results 1 to 13 of 13
    Grand Rapids, MI
    Default Proper Battery Hold Down
    So as I was doing some work under the hood of my '85 LTD I noticed that the battery hold down was missing. The previous owner had the battery replaced among other things recently I suspect when the shop did the work they either forgot or misplaced the hold down. I thought it would be swell to actually have one. I did some searching around, but I don't know what the actual part is supposed to look like. Is it the same as a Mustang for the same year? I found this thing:
    http://www.cjponyparts.com/battery-h...SABEgLYYvD_BwE
    Is this the right part?
    Cant say what was in there
    NPD sells both metal and plastic types
    https://www.npdlink.com/store/catalo...ts-6206-2.html
    I use the plastic style with ss hardware so the battery will come out years later.
    Also fitted a different battery tray to hold the newer Ford 40/96 group battery.
    Many a hold down got trashed because of that frozen bolt/nut/whatever.
    Grand Rapids, MI
    Thank you for the reply. It seems like everybody specs the plastic piece for '87+ applications. I'm open to using either one as long as it fits properly. I'm not looking for 100% concourse correct, but I do want the properly functioning part in there that isn't some universal fits all makes and models part.
    The stock battery tray and hold down is garbage.
    Im gonna be building my own bolt in solution soon that actually will hold it in place.
    Grand Rapids, MI
    Well right now I only have 50% of the stock garbage. I'd be happy with 100% of the stock garbage for now. Does anybody know if either hold down will work with my tray? Again I am assuming the Mustang uses the same parts as the LTD which seems like a safe bet.
    Oct 2004
    Ann Arbor MI
    my 85 and 86 Capri's had the metal clamp. compare your battery group size to a mustang and use that style
    My 1984 LTD has a plastic tray but the hold down piece is metal and it looks orginal to the car.I went to the garge to double check
    The battery trays are the same all the way up to at least the sn-95 v-6's. I pulled the whole tray out and it bolted right in place of my 87 tbird back in the day.
    My 83 has a metal hold down, looks like a flat rectangular washer with a small slot in it in. It has a long 8mm bolt with a solid flange where the threads end. The parts stores metal battery hold down would probably work fine to replace this style. If you need the plastic one, any sn-95 battery trsy at the junkyard will fit.
    The battery has to be the propper style and size, or it won't hold the battery at all. The correct bstter has a small lip on the sides and fits into a wedge on the inside edge of the tray and the hold down is wedge shapped to keep it tights.
    All 4 of my plastic battery trays are broken or so flimsy that i can pull the battery out with the right sized battery and a tight hold down. Thats why i am going to make my own tray to replace it.
    My 1985 Marquis wagon has the plastic tray with the metal hold down bracket.
    x2 lol... here's mine, flat steel strap, j-hooked into an inner fender hole, threaded rod up thru tray hole, and wing nut
    Grand Rapids, MI
    Thanks for all the replies. I haven't had a chance to look at it so I have no idea what size battery is in it right now. It seemed like a relatively tight fit, but I was more focused on getting the valve cover gaskets on at the time. I'll probably just order the steel bracket and go from there.
    Grand Rapids, MI
    Finally got the steel hold down bracket from CJ Pony Parts. It looks decent enough and should keep the battery from flying out of the battery tray if I happen to jump the car 50' in the air. I actually mounted it upside down to how I would have thought it would mount (with the bent flange pointing down) as this seemed to hold the battery the best. Not the most secure thing in the world, but it is better than nothing. Oh forgot to mention. it has a group 56 size battery in there now.
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '97 Thunderbird
    '85 Ford LTD Squire
    You have mounted it correctly. The original finish on the plate was Zinc plated and the bolt was yellow cadinum.
