Results 1 to 10 of 10
    Default Weird ignition switch bolts ?
    Okay so I've searched all over for this. I'm not sure if the bolts (studs?) Holding in my ignition switch are oem, but they're nothing like I've ever seen. Firstly it's not a hollow head that you would stick say a hex or star bit into. The head sticks out so you need to grab it with something. But I've never in my life came across these or a bit that would be able to grab them. They're rounded,almost looked stripped. I read that I shouldn't drill them out etc.
    Now I plugged my new switch in, but kept the old one mounted, and still was unable to turn the motor over by key. So I'm guessing I need to have the switch mounted.
    Also I put a new ignition lock switch (tumbler) new starter solenoid and pretty much covered all other bases.Car turns over by screwdriver on solenoid .
    Thanks in advance !
    Jan 2006
    Western MA
    Yes - it is a weird headed screw. You can either try to grab it with a vice grip (I've never been able to do this) or use a dremel or similar to cut a slot across the head and use a standard flat blade screw driver. I replaced these weirdos on my SVO with standard hex hardware when I changed the ignition switch on my SVO.
    No start - have you checked the clutch safety switch and associated wiring? There is also a jumper (manual) or lockout (auto) on the trans, the wiring for this is fed through the trans tunnel on the drivers side.
    Good luck!
    1986 SVO Mustang - 1C
    Nov 2004
    Chas. SC
    They are a theft deterrent. Otherwise you could unbolt the switch using common tool, override he steering wheel lock and drive away. .
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    The switch is activated by a rod which is connected to the key tumbler. So if the rod is not connected you are not moving the actual switch. Most people snap off the mounting screws and new screws come with the new switch.
    Ive never had new screws included with a switch.
    Some cars had security torx. My 86 tbird had those bolts. They are actually a wing nut style head but reslly thin and designed to break off. Mine also had thread lock. They were not very tight and i was easily able to break them loose with small vice grips and thread them out by hand. I put the same bolts back in.
    Yep - break them loose with a vise grip and put them back when you are done.
    Ford issued a special tool for doing the ignition switch recall that stretched all through the '80s. You might be able to track one down. Any Ford tech that's been around a while will have one.
    What is the special tool?
    I can't find a picture of one (pretty sure I didn't dream it) but it looks like a little ratchet wrench with both sides having the tamper proof torx, one deep, and one very shallow. Meant so that you can just pop off the column shroud, rather than taking the whole dash apart, and zip the bolts out.
    May 2003
    Roseburg Oregon
    A small flat headed chisle will loosen the anti tamper bolt .
    Once removed , you can use a hack saw blade to make a slot , so you can use a screw driver for future service .
