Okay so I've searched all over for this. I'm not sure if the bolts (studs?) Holding in my ignition switch are oem, but they're nothing like I've ever seen. Firstly it's not a hollow head that you would stick say a hex or star bit into. The head sticks out so you need to grab it with something. But I've never in my life came across these or a bit that would be able to grab them. They're rounded,almost looked stripped. I read that I shouldn't drill them out etc.
Now I plugged my new switch in, but kept the old one mounted, and still was unable to turn the motor over by key. So I'm guessing I need to have the switch mounted.
Also I put a new ignition lock switch (tumbler) new starter solenoid and pretty much covered all other bases.Car turns over by screwdriver on solenoid .
Thanks in advance !
