Results 1 to 6 of 6
    Default Back seat weight
    How much does an 85 back seat weigh? Is it quick and easy to r+r.? How much does the passenger bucket weigh(non power)?
    Sep 2008
    Greenwood, IN
    The lower seat cushion is pretty light...and easy to pull out, just pull up hard under each passenger area at the front and it will dislodge the hooks. The rear seat backs weigh the most due to the metal frame and hinge assemblies. Also easy to remove with some hardware near both rear wheel wells and the center joint for the dual seat backs. If I were a guessing man....7-10lbs on the seat bottom and 20-25 lbs on the seat backs (combined). Front seat...easy to remove, no clue on the weight....30-35lbs guess. Will be curious how close (or off) I am if anyone knows for sure.
    Jason Smith
    MCA #65481
    '82 Capri RS Resto-Mod
    '05 S-281 Mineral Grey
    For the bottom cushion, push back (to the rear of car) on the face of the cushion and simultaneously pull up. There is a wire rod that fits into a retainer that has a 'keyhole' shape. Pushing back lines up the rod with the opening.
    1985 GT owned since new
    I just weighed my extra '84 rear hatch seat. The seat bottom is 11.2 and the two upper halves together are 20.7lbs.
    Thanks. Probably not worth yanking them for 60-70 lbs at my skill level. But then again, there's hardly ever someone in the backseat.
    Jul 2016
    Duncannon PA
    I'm think in the front seat is at least 50 lbs.
