can anybody post some pics of their foxbody mustang with a 351 windsor loved to see some other peoples projects
Is there anything in particular you're looking for? Here's a random one of mine from 10 years ago:
408/T5/3.73's
did those long tube headers work my long tube headers which are the same one in the picture would not work they would not clear the flaming river steering shaft along with the firewall on the passenger side the only difference was i had a c4 transmission i just bought bbk ceramic shorty header so hopefully those will work
I didn't have any major header clearance problems with those headers which are BBK swap headers. They wouldn't clear the stock rag joint but once I switched to the flaming river shaft it was fine. They are really close to the very bottom of the firewall on the passenger side but do clear. I'm also running solid motor mounts, don't know if that helps or not. I'm running a T5 but can't see where the transmission would be a problem. I did have some problems with clutch cable clearance that would be avoided with an auto. Switching to the MM clutch cable which is longer helped with that.
408/T5/3.73's
im running the same set up as you except im running a c4 with my 351 i have a aje kmember and a flaming river racka and pinion im not clearing on the passenger firewall or the steering shaft
also i forgot to say im running a maximum motorsports steering shaft with the flaming river rack and pinion
1984 LX 5.0 Vert *SOLD*
Double post... sorry
Not to jack the thread, but mmb617 I am going to do a 351 swap with the BBK headers. I was wondering if you dropped the engine in with the headers on or if that's even possible?
408/T5/3.73's
It's a 600hp N/A 418w, but you get the drift..
1986 CHP SSP Coupe
... with the mailbox with a restriction on the side of it, I'm skeptical of that number, lol...
Nice engines above!
Anyone who has been around a clutch when it decides to scatter can respect the thought of having a shield. I scattered one after routine clutch maintenance about the first time I let out on the clutch. trashed the input shaft on the T5, etc. Lucky nothing broke my bellhousing or.... me.
Mine is a 1983 with 408 in it .![]()
1993 triple white GT
2004 AZ Mach 1
2003 zinc yellow Cobra
1983 410 Windsor tko 500
2004 AZ Mach 1
