Results 1 to 19 of 19
Thread: 351 windsor
    Default 351 windsor
    can anybody post some pics of their foxbody mustang with a 351 windsor loved to see some other peoples projects
    May 2005
    Altoona, PA
    Is there anything in particular you're looking for? Here's a random one of mine from 10 years ago:
    408/T5/3.73's
    did those long tube headers work my long tube headers which are the same one in the picture would not work they would not clear the flaming river steering shaft along with the firewall on the passenger side the only difference was i had a c4 transmission i just bought bbk ceramic shorty header so hopefully those will work
    May 2005
    Altoona, PA
    I didn't have any major header clearance problems with those headers which are BBK swap headers. They wouldn't clear the stock rag joint but once I switched to the flaming river shaft it was fine. They are really close to the very bottom of the firewall on the passenger side but do clear. I'm also running solid motor mounts, don't know if that helps or not. I'm running a T5 but can't see where the transmission would be a problem. I did have some problems with clutch cable clearance that would be avoided with an auto. Switching to the MM clutch cable which is longer helped with that.
    408/T5/3.73's
    im running the same set up as you except im running a c4 with my 351 i have a aje kmember and a flaming river racka and pinion im not clearing on the passenger firewall or the steering shaft
    also i forgot to say im running a maximum motorsports steering shaft with the flaming river rack and pinion
    86 coupe
    1993 GT
    My 10 Sec street cars
    Little 351 project I started about 2 years ago. Car and 351 motor right from the junk yard.
    Here is my 82 GT, been trying to get it to paint for some time now. 357W with a retro hydraulic roller, 11:1 compression, ProComp heads ported, Vic Jr, Tremec 3550, 3.73's, big brakes, koni adj. Recaros! Fun car, cant wait to get it done. Check it out.
    1982 GT 351W, retro hyd roller, ported Pro Comp heads, Tremec, M2300K brake kit, Recaros...needs paint!
    1984 LX 5.0 Vert *SOLD*
    1993 Cobra #3971 mostly stock *SOLD*
    1966 FFR Cobra replica 383W, Vic Jr heads, Vortech YS, TFS Box intake, 652rwhp, crazy fast!
    1987 GT in MM&FF May of 97 "Not Fade Away" white and purple. Sold 1999
    Double post... sorry
    Not to jack the thread, but mmb617 I am going to do a 351 swap with the BBK headers. I was wondering if you dropped the engine in with the headers on or if that's even possible?
    May 2005
    Altoona, PA
    Yes, I've had the engine out multiple times and always left the headers on as there is so little clearance to get at the header bolts once the engine is in place.
    I start it in with a lot of downward angle and level it once the headers start under the firewall.
    408/T5/3.73's
    Apr 2008
    Waikoloa , Hawaii
    It's a 600hp N/A 418w, but you get the drift..
    1986 CHP SSP Coupe
    ... with the mailbox with a restriction on the side of it, I'm skeptical of that number, lol...
    1983 Mercury Cougar 3.8L LS
    1981 Mercury Marquis Brougham
    1971 Mustang Fastback
    1974 Pontiac Luxury LeMans
    Nice engines above!
    Quote Originally Posted by mmb617 View Post
    You race that with a stock bellhousing??? I have a scattershield on mine and I've only made about 10 passes in it! lol
    Mine still has all the factory accessories, including a/c. Is there any problem shoe horning it in with the headers on and the a/c lines or anything?
    Anyone who has been around a clutch when it decides to scatter can respect the thought of having a shield. I scattered one after routine clutch maintenance about the first time I let out on the clutch. trashed the input shaft on the T5, etc. Lucky nothing broke my bellhousing or.... me.
    Mine is a 1983 with 408 in it . Name:  IMG_0605.jpg
    1985 drop top
    2004 AZ Mach 1
    2008 Gt Mustang
    1983 408 Windsor tko 500
    1985 drop top
    2004 AZ Mach 1
    2008 Gt Mustang
