Hello fellow members,
Hi my name is Les I just put in a 91 roller motor that's all stock except the new drop roller lifter, push rods and a new e-cam. I also did a 3g upgrade before the 91 motor it was pushing normal voltage with the all stock 82 motor. Now I just got it running and it's putting out 11.4 volts while running. I had the battery charged and tested and the said that the battery is at 40%. Could this be the problem.
