So mid June my engine blew at the track, I wasn't surprised as I was aware of an engine build error that would some day cause a big failure. Because of that, I have directly coordinated the engine build with a reputable machine shop rather than contract it out to a "pro" mechanic. I hate that I got suckered and believed all his BS!!
So the last engine builder, "expert" was suppose to build a 400 hp at the crank 302 that was going to be sprayed with a 150 shot of nitrous. After the build I came to discover that he put in hyperutectic pistons. So I knew the engine was a time bomb! My goal was a 13.5 on engine.
Since the disassemble, I've discovered that the pistons were also meant for high compression which cause me to scratch my head until I was informed my crank was not for a 302 but rather a 289. The machine shop estimated that the engine, at best was 8-1 compression but more likely 7-1 as the ring gaps were way too big. That explained the all the blow by. I was also informed, mismatched valves of different lengths were used. So is actually amazing that the car did an 11.8 in the 1/4 mile. The piston compression error reduced the wrong crank error.
This really explained why the can never really performed naturally aspirated as it should given all the trick flow heads and all the other go fast goodies. The engine lasted 20 000 km and ran 13.9 at best.
So now I have all the parts ready for a 400+ hp engine. Forged pistons with the correct ring gap, a 302 crank, and correct valves. I also now have a windage tray, main girtle, and 7 quart pan. On paper this 9 1/2 to 1 engine should be epic on nitrous and should hit or surpass my goal of 11.5 in the 1/4 mile.
If all goes well, the 81 cobra will be tearing up the track mid or late August.
