Results 1 to 4 of 4
    Default Pulley help (pulleys from multiple generations and engines)
    I bought a parts lot that came with a 1984 svo a guy was parting out. After laying everything out I realized the previous owner had used turbo coupe parts from 87... I bought this set because he had an ac for sale. The ac has a ribbed pulley. I have many pulleys from ranger and turbo coupes that are all ribbed. Should they swap over? The one pulley I am missing is power steering. any idea on what pulley I can use on the stock power steering pump that I just bought?
    St. Louis, MO.
    So if the PO switch from v-belts to the serpentine belt system you would need the ribbed pulley for your power steering pump.
    Ford #E7SE-3D673-AA.
    Scotty
    Past Pony's.....
    And this will fit the stock power steering pump?
    St. Louis, MO.
    Quote Originally Posted by jfj0002 View Post
    Yep, it's the stock power steering pump pulley for the 87-93 2.3 and the 5.0. and should earlier pumps as well, the stock pump for my 85 2.3 is the same as the my 88 5.0.
    Scotty
    Past Pony's.....
