Hello:
Desperate need of help. I broke one of the water pump bolts recently. Currently the pump is removed as is the radiator and anything else in the way. Likewise the timing cover is off. There was a small piece of the bolt sticking out but my vise grips destroyed it so I ground it down, drilled into the bolt and tried an "easy out". What a joke. They DON'T work. Now I have a hogged up piece of a bolt, and no real way to get it out. Shame to throw away a perfectly good 86GT over something like this. But if I ruin the block...
So any ideas? Better tools of course but I borrowed the easy out set from my work. Again- pure junk. Tried heat. No luck. How far can I drill in before the block is done for? Options?
Thanks.
