Hey guys, the end of this build has been frustrating to say the least. The motor is from a 1988 Turbo Coupe and I am having issues getting the coil to fire. Below is a list of things I know
Coil has 12V
ICM has 12V with key on and start wire has 12V when cranking
Coil voltage drops to 6 or 7 when cranking... which is weird.
The distributor spins
The distributor is brand new, so is the module
I have a known working module from a working car and it makes no difference
Test light is showing zero spark from the coil while cranking
The spout and pip wires go to their proper locations and seem to be undamaged
I can sometimes get the coil to spark once by rotating the distributor by hand
What is bugging me is the voltage drop at the coil during cranking. I am thinking that 7 volts is not enough to fire the coil. I have no idea why its dropping that low during cranking.
