Results 1 to 8 of 8
    Jul 2016
    Duncannon PA
    Default 1985 A/C cutout switch
    Does the a/c cutout switch on the carb need to be connected at all for the a/c to work? The wiring is there but I have a Holley 600 on the car now so no solenoid.
    FEP Super Member escogt's Avatar
    Jan 2006
    Long Island, N.Y.
    Yes. It needs to be connected for the A/C to work.
    '85GT Bright Atlantic Blue
    '92LX Bimini Blue-sold
    '93 COBRA Teal Metallic-sold
    '86SVO Oxford White-sold
    '86GT 'Vert True Blue-sold
    '81'GT' Medium Red-sold
    Just install a jumper wire in the plug. Thats what I did on mine.
    Jul 2016
    Duncannon PA
    Is it the two pronged female plug with one red wire and one black with green stripe wire? If it is, I have no power to it and nothing at the clutch plug either. I do have power at the pressure switch back by the firewall on the drier. Is the black wire on the drier a ground wire or are both wires hot? I only checked the pink? wire.
    the WOT switch wires are red/yellow and solid red. You can jump those. Or jump the wires at the WOT relay. jump the pink/ light blue wire to the black/ yellow wire
    Jul 2016
    Duncannon PA
    Quote Originally Posted by Lowetlx View Post
    Where is the relay at?
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    Quote Originally Posted by dagenham View Post
    I believe it's under the dash on the pass side near the TSAD computer.
    '85 GT
