    Default What Size Tires For Crown Vic Wheels
    Thinking about getting some Crown Vic 1998-2002 16"x7" steel wheels for my 5 lug conversion. Is anyone using these what size tires are you running?
    On a 7" wheel you are generally looking at a 215, 225, 235 wide tire. You can probably go smaller, but why! A 245 will fit on the 7" wheel, but you are starting to stretch it at that point.
    Most likely the SVO 225/50/16 size will work best for you. Best of luck!
    Mar 2013
    Where the Navy sends me...
    The stock GT / LX 5.0 size on the 16x7" Pony wheels was 225/55-16. I didn't realize SVOs used 225/50s.
    So, go with 225s, and choose whichever aspect ratio gives you a diameter that best matches the stock tire diameter (so the speedometer and odometer aren't thrown off).
    Hey Guys thanks for the reply's. I was working a deal that included 4 like new crown vic wheels but it didn't work out. Thanks
    Crown vic rims.
    see example
    http://www.carid.com/1998-ford-crown...-16114932.html
    crown vic center caps
    see example
    http://www.ebay.com/itm/like/141459503676?lpid=82
    trim rings
    see attached link
    http://www.amazon.com/Stainless-Stee...%22+trim+rings
    i when with the non shinny rings so they matched the crown vic center caps.
    the reviews on the rings are mixed but i had no issues with shipping or fit .( the retainers on the back will scrape of your paint like the one reviewed said)
    tires
    225/55zr16 95w
    Name:  1982 mustang drive side.jpg
    1982 Mustang coupe with 66 mustang 289(30 over, keith black pistons,etc.) 4cyl world class t-5, 8.8 with 3.55.
    1980 Mustang hatch(sold)
    1965 Mustang (in process)
