Predator # 4S102 is not running correctly. Everything is stock and all emissions are present on the car. I had the carburator rebuilt in the fall and the car was running fine. Took it out for a long drive and it started to sputter at 45 - 50 MPH. The more gas I gave it, the slower it got and would not rev. If I came to a complete stop, I could rev it and take off just fine but as soon as I got to 45 - 50 again same problem. I have replaced the coil and duraspark and this did not help. The fuel pump was replaced when I did the carb. All fuel lines are new. I spoke with the carburator shop and they gave me a couple of things to try, removing the gas cap to see if it is a venting issue, also pulling the large hose off the front of the carb as it has been kinked. These things also did not help, in fact, now the car will only move at idle and if I give it gas it will die. So it is to the point now where I cant even take it for a test drive for fear of having to leave it on the side of the road. The carb shop also said that the sock in the tank could be pulled into the gas line, cat could be plugged although it was not glowing red when I got it home. Any suggestions?
