Results 1 to 4 of 4
Thread: LTD T5 swap
    Default LTD T5 swap
    Currently sitting here under the dash of my ltd and cannot for the life of me find the plugs for the manual pedals. Who has done this swap and can say where they are?
    I have looked in the kick panel area but all the wiring runs up into the metal framing plus my insulation is in the way
    Quote Originally Posted by wdanison43103 View Post
    I looked everywhere in the kick panel and under the dash of my 1985 LTD LX when I did my 5 speed conversion, never found them. I just wired the clutch switch directly to the wires that were coming from the neutral safety switch on the AOD wiring. Same with the backup light switch, just used the original wire harness.
    Sent from my SM-G955U using Tapatalk
    was your LTD CFI? Im wanting to t5 swap my 84 CFI mustang and i hear some guys get weird idle issues, I =m not afraid to go carbed, but i have an
    urgent need to get the car moving under its own power immediately, the motor runs excellent, I just swapped in a 91 f150 motor, with all the old cfi equiptment. Also your answer gives me alot of answers to set up my clutch safety switch thanks!
    Sorry man it's been a while wince I've been on here. Yeah my car was CFI when I first did the T5 swap. It ran ok but had a slight hesitation going into first gear, but other than that it was ok with the CFI. I ran it like that for about 3 months before I went to a carburetor.
