Results 1 to 4 of 4
    Default 9F03F129208 Decode
    VIN
    9 = 1979 model year
    F = Dearborn Assembly
    03 = Mustang 3-dr hatchback
    F = 5.0L V8 engine
    129208 = 29,208th 1979 Ford scheduled for production at Dearborn Assembly
    Door Tag
    Date - 10-78 = October 1978 scheduled build
    GVWR - 3903 lb/1770 kg = gross vehicle weight rating
    Front GAWR - 2104 lb/954 kg = front gross axle weight rating
    Rear GAWR - 1819 lb/825 kg = rear gross axle weight rating
    F0051 = 51 lbs front accessory reserve load
    R0080 = 80 lbs rear accessory reserve load
    Exterior Paint Colors - 1C = Black
    DSO - 21 = Atlanta district sales office
    Body - 61R = Mustang 3-dr hatchback
    Int Trim - LA = all vinyl seating, high back front buckets (L), Black interior color (A)
    A/C - A = manual air conditioner
    R - [blank] = no radio?
    S - [blank] = no sunroof
    Ax - B = 2.47:1 axle ratio, non-locking differential
    Tr - W = Ford C4 automatic transmission
    MM = front springs
    MM = rear springs
    Buck Tag
    F = 5.0L V8 engine
    MR = moonroof (sunroof)
    0137 = body & paint rotations #0137
    1C = Black exterior paint color
    A = Black interior trim color
    DF
    TT = Black lower exterior paint color (lower tu-tone)
    M
    AC = manual air conditioner
    DRM = dual remote mirrors
    CBR = Cobra package
    WQM
    3 = forward-facing non-functional hood scoop
    4
    6
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Door tag does not have sunroof code.
    Buck tag does have a sunroof code.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Okay, the suspense is killing me. So what does the car actually HAVE?
    John Adams
    July 7, 1775
    Owner said the car does have a sunroof. I figured it did since the buck tag tells the B&P line which holes to punch in the bucked body.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
