Results 1 to 4 of 4
    Default Intake Manifold - Heater Delete 83 gt
    As my heating system was not in the best of shape I have taken it out for the time being on my 83 GT. Now I am left with a space on the intake manifold where it used to connect to the heater core, what size bolt/fitting can I put in there to seal it ?
    Using weiand stealth ii intake
    1981 Mustang Hatch 3.3 "Orange Juice"
    1983 Mustang GT Convertible "Triple Black"
    1994 Ford ThunderBird SC
    1987 Firebird T/A
    1984 Firebird Forumla
    1988 Mazda RX-7 Infinity
    1987 Mazda RX-7 Turbo II
    1994 Eagle Talon TSI
    1991 Eagle Talon TSI
    2003 Pontiac Grand Prix GTP
    I would not recommend a bolt as the hole in the manifold is designed for a pipe fitting.
    Most likely the fitting will be anything from a 3/8 to 1/2" NPT. Go to Home Depot, Lowe's, or your local hardware store to purchase the pipe plugs. You can get a rough idea of the size by what size bolt will fit in the opening. You might need to buy a couple of sizes to be safe if you are unsure of the sizing. Either way you can take them back for a refund if not used.
    Otherwise you can order plugs from Summit Racing, Jegs, and others online if you want something that is more aesthetically pleasing! Good Luck!
    Pipe sizes and bolt sizes have no relation. Here is a link to basic pipe dimensions: http://machiningproducts.com/html/NP...imensions.html
    It was 3/4 mpt
    Sent from my F8131 using Tapatalk
    1987 Firebird T/A
