Results 1 to 13 of 13
    FEP Member Dave9052's Avatar
    Jun 2016
    Saint Clair MI 48079
    Default 83 gt vert. Fox Chassis
    As promised here is my cars body tag. I have posted prior to today copy of window sticker but have posted it again. I still have not found buck tag but will look again Thanks DaveName:  IMG_1770.jpg
Size:  137.5 KBName:  IMG_1797.jpg
Size:  121.5 KBName:  IMG_1851.jpg
    Thanks for the door tag and the re-post of the window sticker Sometime even if you know where to look for the buck tag it's hidden.
    Between the hood latch and the driver side headlamps, attached to the front face of the radiator 'core' support (frame that radiator bolts to) you'll see two brackets. The bracket on the left holds a line from the power steering pump. The L-shaped bracket on the right holds the header panel (frame that headlamp buckets attach to) to the rad support. If you peek behind those brackets the buck tag may be there. The buck tag is attached to the core support before anything else.
    Buck Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Jun 2016
    Hello, FoxChassis the buck tag is MIA not there. But here is axle tag.Name:  IMG_1882.jpg
    3F22 = built June 22, 1983
    3L08 = 3.08:1, Traction-Lok differential
    7 5 = 7.5" ring gear
    S271D = 1982-83 28-spline 7.5" 3.08:1 T-L
    Buck Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Jun 2016
    Thanks for all the information!
    Jun 2016
    Marti report ordered on this car will post soon! Received this today; anyone ever get response like this?-------- Original Message ----------From: sales@martiauto.com
    To: dhilgendorf999@comcast.net
    Date: July 18, 2017 at 10:13 AM
    Subject: Marti Auto Works order #3899535-D
    David Hilgendorf,
    If you have the original vehicle certification label (paper door sticker) for VIN 1FABP27F6DF204420 , it would be greatly appreciated if you would provide us with a picture. The information on the vehicle certification label will be used in our continuing research efforts.
    Should you be able to provide us with a picture, you may forward it to us at sales@martiauto.com.
    If you are unable or choose not to provide us with a picture, this will in no way effect or delay completion of your order.
    A picture of the vehicle certification label is not required to complete your order and is requested for ongoing, in-house research purposes only.
    Thank you,
    Marti Auto Works
    Yah they ask you when they don't have it, it's legit.
    1981 Mustang Hatch 3.3 "Orange Juice"
    1983 Mustang GT Convertible "Triple Black"
    1994 Ford ThunderBird SC
    1987 Firebird T/A
    1984 Firebird Forumla
    1988 Mazda RX-7 Infinity
    1987 Mazda RX-7 Turbo II
    1994 Eagle Talon TSI
    1991 Eagle Talon TSI
    2003 Pontiac Grand Prix GTP
    Probably for two reasons...
    1. They dont know all of the info for each VIN's door tag because Ford didn't save gross vehicle ("GVWR" numbers) and axle weights ("GAWR" numbers), accessory reserve loads ("F" and "R" numbers), special paint codes, or spring codes (last four of the "TR" code).
    2. Sometimes codes change in the middle of the year, or they're unique for one year. Ford just did these things but didnt note it anywhere in their books, so obviously Marti Auto doesn't know and therefore doesn't know to do it exactly like Ford did. Some examples:
      • "A/C" code changed use in the middle of the 1983 model year
      • lower tu-tone paint code wasn't on 1979 tags
      • vinyl roof ("VR") code was repeated on the "EXTERIOR PAINT COLORS" line in 1979.
      • sunroof ("S") code was unique in 1980 ... sunroof was "B" instead of "C" like every other year, and NO sunroof was "0" (zero) instead of blank like every other year.
    Buck Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Jun 2016
    I sent the pic. yesterday, I have never had them ask me any questions on past Marti reports. Thanks for the info. and all you guys do for everyone on FEP.
    Other people that have collect hundreds or even thousands of samples of different door tags, me included, have sent Kevin Marti specific years upon request. I'm guessing that Marti Auto is probably making this request now, from all new deluxe report orders, as this would increase the pool of potential copies of door tags so they could study and document the changes.
    Buck Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Jun 2016
    Marti report, Not much new information that was not on window sticker.Name:  IMG_2009.JPG
    FEP Power Member Bryan Knebworth's Avatar
    Sep 2010
    Lexington, MA
    Quote Originally Posted by Dave9052 View Post
    Well, now we know for sure the production number is 993. As if there were ever any doubt
    Jun 2016
    Yes Bryan that is true !
