79 cobra last stand
79 cobra turbo four, ames iowa. Not really sure how to market this one. $1 and up. There isn't much left of this one and she's loaded for scrap, but I hate to lose even one part someone can use. Highlights are sailpanels, what appears to be an uncut engine harness with many solenoids voltage regulator etc still attached, sunroof (not sure if it's oem, one of you pros will know), and a plethora of screws clamps and brackets. I pulled the little seatbelt donuts for someone already, so you don't know unless you ask. If this is improperly listed I apologize in advance. Calling would be best 5152313447- Shane. And thanks for looking
Are the rockers and quarters in decent shape? How about the floor?
too bad 86 vs 79 doors don't play well together as they look like they might be decent shape
what about frame rails and core support, hatch, etc?
It is typical of Midwest rust buckets. It is possible I may be able to cut small patches from the floor. The core support is good, however it has succumb to the losing end of many parking curbs. I do make it to the big O regularly fyi
New User
It seems to have the crank windows, if so, I'm interested in the passenger side door guts. All pieces that pertains to the window regulator and door lock mechanism. May I have pictures of the interior side of the passenger door too please. I may be locked in for the door panel too. Thank you.
- You may not post replies
- You may not edit your posts
Forum Rules
