THE NUMBER OF THE BEAST
OF14A646877
THNX!
O - Model Year 1980
F- Production Plant, Dearborn, MI
14 - Capri Bodystyle
A - Naturally Aspirated (non-Turbo) 2.3 inline four cylinder
646877 - Consecutive Unit Number 46877
I think that something is wrong...... the car came with the turbo, it is a Mercury Capri RS Turbo. are you sure that the code is OK?
thnx!
Does the original door tag still exist on the car?
All decoders I have list A as a naturally aspirated, non-turbo engine code. Turbo RSes would have W as the engine code.
I will look at the door.
thnx!
Try to either take a good picture of the door tag or record everything as it is on there.
Also, take a look at the core support/radiator support on the car. If you can find it and write down all the codes on that, it's further documentation about what the car is and is not.
The thing is, you could get the RS package with any available motor.
- You may not post replies
- You may not edit your posts
Forum Rules
