This clean 1985 Mustang GT is for sale and is located in northern Wisconsin (Land O Lakes). I am asking $9500 or good reasonable offer. Looks like only 5 pics can be added per post, so I'll be adding more in sperate posts.
This car has been my project for the last year. I disassembled nearly the entire car. I documented as much as I could with photographs. This was a nearly rust free car with the usual dings and original failing paint. A prior owner had already replaced the original engine with the one that's in it now, along with some other mods. The rust was limited to surface rust on the bottoms of the doors and rear bottom edge of the hatch. There was no rust-through in those areas and it cleaned up nicely down to clean, solid steel. On the rear bottom edge of the right fender, there was an area the size of a quarter that rusted and had pin holes - I cut that out and replaced it with new steel. Some stone chips had very minimal surface rust that also cleaned up nicely. That was it for rust. Some prior owner sprayed undercoating all over the bottom of the car. I removed all of it and found that everything was solid - no rust. The floor under the driver's seat had a minor crack from the flexing that occurred on these cars. Those cracks were welded. During disassembly, I found an almost intact build sheet under the carpet under the passenger seat. Under the front bumper cover I found a clean Hollerith card taped to the steel bumper. I gave it to a member of this site. I thought those finds were pretty cool. So, this was a solid car to begin with.
The bottom of the car was properly prepped and painted with grey Rust Seal (like POR 15). The engine bay was cleaned and I welded all those unused holes shut. The "frame rails" were boxed in as well. I tucked the engine bay wiring harness behind the fenders and firewall for a clean appearance. In 2016 the engine bay, jams, and the rest of the panels were painted in the original medium charcoal grey using PPG and SPI bc/cc. The paint is very nice but not perfect. There are a few chips and a small dent (not obvious) on the driver's door from reassembly. All the weatherstripping is new. These t-top cars often had problems where the roof panel separates from the t-top frame. This issue was corrected with new rivits and panel adhesive, it's solid now.
The interior is nice and clean, but not perfect. Lizard skin was sprayed on the floor under the new carpet. All of the interior panels were properly cleaned and prepped prior to being repainted. The headliner is new.
I've owned this car for something like six or seven years. It's stored in a heated shop and I've never driven it in snow, not even in rain. I don't think the car has ever been in snow. This is just a very clean, fun, street car that turns heads wherever I go. It hasn't been raced and is adult owned.
The engine is a solid running, carbureted 306 with under 5k on it. The prior owner had the engine built by R-T Speed Shop in southern WI. It doesn't burn oil and cylinder compression is 175 - 180 across all cylinders. It starts right up everytime and runs nicely. If I were to guess, if say it's got something like 350hp at the crank. This is a this is a five speed car with the T5. The clutch works fine and the flywheel was resurfaced this spring.
Some of the mods are:
Ford Racing aluminum driveshaft
8.8 differential with 31 spline Ford traclock & 4:10 gears
31 spline Alloy axels
17x9 Cobra R wheels, the tires are good
Full length Maximum Motorsports welded sub frame connectors with seat reinforcements
Stock brakes, with braided stainless flex lines, upgraded rotors, new pads/shoes/wheel cylinders
New SVE aluminum radiator
New SVE high torque mini starter
Mac exhaust, Cerakoted long tube headers, dumps (new stainless tail pipes, not installed)
Cervini 2.5" hood
New Ford Racing lower front control arms and ball joints
Lakewood traction lift bars
Pertronix rev limiter
Autogage tach and shift light
K/B hyperutectic Pistons
1.6 roller rocker arms
Trickflow pushrods
Edelbrock Airgap intake manifold
Clevite bearings
ARP bolts
7qt Canton oil pan
Comp Cam hydraulic cam, FS XE274H-10
1979 302 block
1966 289 heads, ported/polished, not sure of valve size
So, like I said, this is just a very clean, fun street car. Enjoy it like it is, or make your own mods to take it to the next level. I'm open to a reasonable offer.
