Results 1 to 9 of 9
    Default 1982 coupe 5.0 fuel injecttion swap help
    I have a 1982 Ttop coupe and a wrecked 1989 5.0 coupe Im converting the Ttop coupe over to all 1989 interior, wiring, engine, lines, and suspension. i will leave the four eyed look on the out side. i had a few rust spots on the front end battery acid leaked and rusted out and hood hinges also rusted threw so i put the front end and cowl off a 1987-1993 mustang just a little background for you. My question is what is the best way to wire the headlights and taillights and the other is is the 1984 bumper cover available aftermarket cause i like the looks of it.Name:  IMG_5578.jpg
Size:  96.3 KBName:  IMG_5534.jpg
Size:  128.6 KBName:  IMG_5577.jpg
Size:  132.1 KBName:  IMG_5812.jpg
Size:  122.7 KBName:  IMG_5802.jpg
    Apr 2009
    Denver, Colorado
    What color was the org interior?
    Current rides:
    89 LX 5.0, 5 -spd..the Lemon
    86 RS Capri 5.0 Auto...
    85.5 SVO, Finally Got Boost
    You want to put a four eyed interior in an 89, all for helping. Going the other way, not so much.
    Good luck, but read the forum rules.
    I have a 1982 Ttop coupe and a wrecked 1989 5.0 coupe Im converting the Ttop coupe over to all 1989 interior i think you misread
    Dec 2011
    stanton,alabama
    The main issue is the area where the pcm sits in the 89 model that area is not big enough in the 82 model and the hole is not big enough for the harness to fit through the firewall
    Apr 2016
    Sprague River, OR
    You will most likely need to combine harnesses and split them by function if you want to run different things like headlights and taillights from different cars. You should have the harnesses from the T-top now to make the lights work. They may not connect to the '89 interior easily, so try looking through service manuals and see how to wire them up.
    I don't know of any '84 front ends as aftermarket. '85/'86 are all I usually see.
    I am doing something similar ('92 v8 drivetrain in an '80 notchback), so i feel your pain on the wiring. Good luck.
    Join The Conversation
    I have a suspicion that you will not find such an admonition in the forum rules but if it is there please point it out to me. I would be curious how I missed that passage after all these years.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Quote Originally Posted by onetrackrider View Post
    Original interior trim color was Vanilla, with cloth & vinyl high-back front buckets.
    http://vb.foureyedpride.com/showthread.php?180603
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    I put a '90 harness in my '79 Zephyr. You have to modify a few things, but wire colors are all pretty much the same, so splicing in your exterior functions like wipers and lights is not difficult. You can even end up with delay wipers if your '89 had them.
    That said, my pcm is currently floating above my passenger footwell. I haven't figured out what to do with that yet. But since you're no stranger to sheet metal work, you could swap over the pcm pocket in the passenger kick panel area.
