Today I finally replaced the 11A1195 A/C fan belts with shorter 11A1015 non A/C fanbelts as a provisional measure after a previous driver sh99ed the FoMoCo York compressor itself due to not having enough oil in it
At the same time, my son Ashley (Ash) did a
partial strip out of the front part of the bumper and guards. Due to the fact that I have to use the car at night for auditing and road roughness, I can't remove any of the wiring or lights to get the guards clear of the inner catwalks where the buck codes sit. If my lights are out of adjustment, I could have some issues with the validity of my reports, or find myself liable if my lights are not working or not factory functional while conducting a Night Drive-over.
After a little discussion with Ash, we
1. got Moms vanity mirror, cleaned it up with some Windoline, and
2. took a few snaps with my A495 Canon.
3. We have a big 42" screen for State Highway Auditing, and we got this to look blow the image up after we first flipped the image and rotated it 180 degrees.
4. Good news is thew whole vehicle is uniform. The buck code is indeed R101037, exactly the same as engine number. Great to know team!
Buck code same on both sides. So the tendered VIN no on the dash is
not the same as the body and engine. Hence I've got to find the actual VIN with its proper sequence number, and search that for my Marti Report, as well as the tenderd VIN number. Since the engine number and buck code aggree, I've got to go back to Vehicle Identification New Zealand, and update them on the correct engine number, and find evidence that the VIN numbers were changed at some stage from two independent sources.
Normally this is done by IVS (Independent Verification Services Limited), and the details matched when imports arrive in New Zealand, but for some reason, perhaps due to the non invasive nature of New Zealand inspections from 1990 to last year, the errors and requirements weren't resolved satisfactorily. I've worked with these guys and normally, the cars just sit untill the situation is resolved. If it isn't, the vehicle can potentially be send back to the country of origin.
Without further adoo, here are the Flipped and Rotated Passenger side Mustang photo confirming the buck code is in line with the engine number.See how it lines up with the original engine number
And some other snap-shots while my 20 year old got heavily into the verification process. Took from 2.19 to 4.32 pm for him to do it, top job!
