Results 1 to 7 of 7
    Default Can someone help decode this door tag on a 78 fairmont futura
    Can someone help with decoding this?
    VIN
    8 = 1978 model year
    E = Mahwah Assembly
    93 = Fairmont 2-dr Sport coupe
    F = 5.0L V8 engine
    150066 = 50,066th 1978 Ford scheduled for production at Mahwah Assembly
    Door Tag
    Date - 01/78 = January 1978
    GVWR - 4154 = 4154 lbs gross vehicle weight rating
    Front GAWR - 2165 = 2165 lbs front gross axle weight rating
    Rear GAWR - 2007 = 2007 lbs rear gross axle weight rating
    F0025 = 25 lbs front accessory reserve load
    R0050 = 50 lbs rear accessory reserve load
    Color - 81VD = Russet Metallic exterior paint color (81), Valino Grain vinyl roof (V), Russet vinyl roof color (D)
    DSO - 25 = Richmond district sales office?
    Body - 36R = Fairmont 2-dr Sport coupe
    Trim - HE = cloth and vinyl seating, front flight bench (H), Russet interior trim color (E)
    Sch Date - 23A = January 23 scheduled build
    Axle - B = 2.47:1 axle ratio, non-locking differential
    Trans - W = C4 automatic transmission
    A/C - A = air conditioner
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    VIN
    8 = 1978 model year
    E = Mahwah Assembly
    F = 5.0L V8 engine
    Door Tag
    Wow, that was quick. Thank you!
    Sent from my SM-J320V using Tapatalk
    VIN
    8 = 1978 model year
    E = Mahwah Assembly
    F = 5.0L V8 engine
    Door Tag
    Wait so this is an really early car then?
    It's about a mid year 1978 model. Model years start in August/September of the previous calendar year, not January. For example, a 1978 model would start production in August/September 1977.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Apr 2010
    Portland, Oregon
    Mick: do you have any timelines of Fairmont production at different locations.
    My 12/77 boxtop was built at the St. Thomas plant (and went to California) while this Sport Coupe was built 01/78 in Mahwah.
    I was generalizing with my August/September production start and end. Each plant is different and they did not intermingle the consecutive unit numbers (last six of VIN) between plants.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
